510 Diesel combine question
Micah Mitchell
01-26-2008 15:47:13
I have a 510 with a perkins 354 and we have to bleed the fuel system after it sits for a few days. I have had someone tell me that the problem is that we have the wrong gaskets for the fuel filters. Does anyone know anything about this? The problem did start after we changed the filters. Any help would be appreciated.
chuck bergstrom
01-26-2008 18:46:14
 Re: 510 Diesel combine question in reply to Micah Mitchell, 01-26-2008 15:47:13
Micah, Your problem does sound like the fuel
filters air leaks but if not: MF had a service
bulletin back then addressing this problem that
they solved by furnishing a check valve for the
line from the fuel tank to the engine. I cannot
remember all the facts but a MF dealer should be
able to pull up. I do have all the bulletins but
access to them & my schedule would mean a few days. Chuck
J Heitkemper
01-26-2008 16:49:34
Based on My Experience ,,I would tend to agree with SOMEONE,, You are getting an airlock Somehow ,,Been There , Done that ,AND Fixed that ! Cummins Dodge Truck , Perkins in a 300 MASSEY , My brother currently wrestling with a 4000 ford with Similar problem.
Lance Newhall
01-26-2008 17:45:19
 Re: 510 Diesel combine question in reply to J Heitkemper, 01-26-2008 16:49:34
Hello
I have seen this many times.when changing the fuel filters people tend to put the square cut oring on top of the fuel filter instead of up in the groove in the housing.When you put the oring on top of the filter it covers to holes in the filter and the fuel will not flow.
Good Luck Lance
