Help!!! ferguson FE 35 problems
Gareth
12-09-2000 08:29:03
i have a slight problem with the small hole under the tractor on the gear box wich is in line with the oil plug, there is oil leaking out out of that hole!!! what has gone wrong and how can it be fixed????? ?? if anyone has a diagram of the inside of the tractor that they can send me or if you have any info please let me know!!!!!
rod
12-09-2000 11:32:17
 Re: help!!! ferguson FE 35 problems in reply to Gareth, 12-09-2000 08:29:03
I think the hole you are referring to is a weep hole to let oil that may seep from the rear engine seal out. It should have a cotter key in it if it is really pouring out you may have to break tractor apart and replace the rear engine seal. regards
rod
