Diesel in crankcase
Okie-Dokie
01-22-2008 12:36:46
Getting lots of diesel in the oil pan. I would imagine it"s the injector "O" rings going bad. Tractor has been sitting for several months without use. How hard is it for an amature to change out those "O" rings? Thanks!
Okie-Dokie
01-22-2008 16:20:35
 Re: Diesel in crankcase in reply to Okie-Dokie, 01-22-2008 12:36:46
Wow!Thanks everyone for the quick informative answers to my question! Looks like I better start shopping for that primary lift pump!
chuck bergstrom
01-22-2008 12:45:32
Hi, What model do you have? Most generally it is
the lift pump (fuel pump)on Perkins engines. Chuck
MF Poor
01-22-2008 14:10:00
 Re: Diesel in crankcase in reply to chuck bergstrom, 01-22-2008 12:45:32
2nd that. Lift pump (primary pump) can (A) leak fuel externally. (B) Allow air in the system, causing air lock of injector pump (C) Leak fuel internally, ending up in crankcase. Rebuild kit OR new pump is a quick cure.
DavidP, South Wales
01-22-2008 14:22:52
 Re: Diesel in crankcase in reply to MF Poor, 01-22-2008 14:10:00
Hi, agree with everyone else.
95% probability that the lift pump diaphragm is perished or split.
4% for the seal in the front of the main pump leaking.
1% for the thermostart leaking.
DavidP, South Wales
