101 Jr oil pressure
Ralf from MIch
01-18-2008 18:57:21
Have a 140 I just got running but it only shows about 8 pounds oil pressure ( new guage and lines ) looking in ITT book it says on the 4 cyl cont you can increase the oil pressure by turning a screw on the right side of the block. Would this be behind the cap in the middle of the block looks to be maybe 1 1/8 cap. Has anyone ever done this? What way turns up and by how much Thanks
Bruce S
01-20-2008 05:53:40
 Re: 101 Jr oil pressure in reply to Ralf from MIch, 01-18-2008 18:57:21
According to my 1952 MoToR's Truck & Tractor Repair Manual for Continental engines it says, "On most engines , the oil pressure regulator is located on the camshaft side of the crankcase opposite the center camshaft bearing. It is sealed by a hexagonal cap. The pressure is regulated by a spring that fits into a piston-type pressure relief valve. Different size springs are available to raise of lower the oil pressure."
