MH 33 numbers what do they tell you guys
old
01-17-2008 10:26:46
Well I found a few numbers today after cleaning off a few areas. Between the clutch pedal and PTO handle I can see 33G1RH
862
Then on the side of the transmission case theres 764795M
Do any of these numbers give you guys an idea of what year it might be. Thanks
44 massey
01-17-2008 19:13:48
 Re: MH 33 numbers what do they tell you guys in reply to old, 01-17-2008 10:26:46
Dose your 33 have live pto with the hand clutch??
old
01-17-2008 20:32:00
 Re: MH 33 numbers what do they tell you guys in reply to 44 massey, 01-17-2008 19:13:48
Not sure can you explain that to me?? I'm not much of a massey man so I'm sort of on new ground with this one. I have had a few MHs but not many
Dave_Id
01-17-2008 14:21:16
The 33G1RH # is the serial number. The tag number was the same as what is stamped on top there. It's a 1954 Model 33 Gas, Regular Altitude (1), R=Rowcrop, I have no idea what the H stands for.
old
01-17-2008 10:47:24
Missed one of the numbers in the 2nd one. so it should be 8862.
So if I'm reading things right it should be a 1954 Correct??
Thanks
