MF 65 hydrolic pump
massey bob
01-15-2008 20:18:34
the pump on my 65 started getting jerky whene i would lift the 3 point and then just quit working none of the outlets work either am i better off buying a new pump or can a guy rebuild it
Jeff-oh
01-17-2008 12:47:59
 Re: MF 65 hydrolic pump in reply to massey bob, 01-15-2008 20:18:34
If you need to put in a new PTO seal while it is out I found that a 2" Schedule 40 PVC coupler is just the right diameter to drive the new seal in place.
Geoff in Scotland
01-17-2008 08:49:46
Have to agree with all other replies....have you tried draining some oil out and removing the right hand back end housing side plate and see what happens when the sontrol lever is operated....or try moving the control valve lever manually with the engine running and see if the lift works any differently
massey bob
01-16-2008 13:33:23
I think a new one is oround $370 i think i will rebuild it i tried new fluid,filters she just wont work I have 2 diesels the other one works great thanks for the info im in wisconsin. I do have a massey dealer little spendy so i think i will go aftermaket any body use aftermarket how do the parts hold up
Aaron Ford
01-16-2008 06:08:23
The pump rebuild kit is only $160 and it is pretty straightforward work. You might even go a little further and put a 20 buck control valve in her... The piston blocks come preassembled, so all ya hafta do is bolt the thing together. Mine took an hour on the kitchen table. Never done one before. Listening to the wifes "concerns" took longer than that.
Pull the lift cover and PTO shaft and she comes out the top. I put new seals in my PTO. Might have put a bearing in there, can't remember. The parts from this site are top notch as far as the pump is concerned. Mine was a Sparex kit. Even had a Sparex part number. Good opportunity to clean out the belly while you are in there...
Where are you located?
Aaron
Jeff-oh
01-17-2008 12:46:30
 Re: MF 65 hydrolic pump in reply to Aaron Ford, 01-16-2008 06:08:23
Ha!!! ain't that the truth.
Our Farmer
01-16-2008 05:52:19
Have you pulled the top cover to see if the filter is clogged up?
You can rebuild it, but it I found it cheaper and easier to buy a used one from a boneyard. I think it was in the $300 neighborhood. Got it from Wenger's in PA
