Leaking Tranny Fluid from Wheel Hub?....Huh?
Craig Ellis
01-15-2008 14:39:43
Ok guys, my Massey 135 that I have been working on has all of a sudden started to leak new oil from the wheel hub... Why the heck would it be doing that?
Thanks fella's
Craig
Geoff in Scotland
01-17-2008 08:54:12
 Re: Leaking Tranny Fluid from Wheel Hub?....Huh? in reply to Craig Ellis, 01-15-2008 14:39:43
Craig I think the half shaft oil seal or the one in the end of the axle housing will most likely be leaking....you will have to remove the wheel....brake drum and then have a look inside then if you have to you will have to remove the halfshaft and relpace whatever seal(s) are leaking....it's really a straight forward job..... Geoff
DavidP, South Wales
01-16-2008 09:07:14
Hi Craig,
I assume that its the rear hub of your 135 that you are referring to. Has it been standing for some time? Have you had either of the axle assemblies out? If you want to replace the hub you will need to have facilities to cut the shrink on collar, a puller to remove the hub and a torch to heat the new collar to fit it.
Please come back if you need any more help.
DavidP, South Wales
Uncle Bubba
01-15-2008 19:13:05
I don't think it's a seal on mine cause it's a pin hole I can see in th casing like an overflow or air vent just don't know why it's all the sudden leaking.
Mike Hunter
01-15-2008 18:50:59
I have a MH35 combine that leaks oil at the final drives. Whats the fix on this/ Who has the seals?
Uncle Bubba
01-15-2008 17:26:08
I have a 165 that I changed the outer planetary fluid in and every since there is a pin hole that fluid has leaked out of. I know it"s not overflow cause it drains the case over time.
ford-s
01-15-2008 16:47:24
try this site under'parts',I have ordered parts from these people with good results,cw
Mike Hunter
01-15-2008 14:44:20
Me to, my MH35 combine is leaking oil out of the final drives. Were do I find seals for this? Mike
