MF20 diesel with MF32 loader questions
paulatclf
01-15-2008 06:39:30
We have an MF20 diesel/industrial equipped with an MF32 loader attachement.
Does anyone know the lift capacity of this combination? I'm using a flail mower as a counterweight.
I need to off-load a semi truck of loaded pallets (I have MF fork attachment that I'll put on after scoop removed).
Is there a capacity difference between this machine's ability to LOWER a load, and to RAISE a load? Keep in mind--deck height of a semi is around 4 feet.
Anyone have a manual on the loader itself?
Thanks!
Grampy
01-15-2008 20:54:14
 Re: MF20 diesel with MF32 loader questions in reply to paulatclf, 01-15-2008 06:39:30
I have an MF40 Ind. with that loader. Dave"s right, it has to be rated at the bucket pins. I have a set of forks that bolt to the bucket. I have occasionally used it to move a round bale, ( ours run about 1400 lbs. ) just barely does it, weight too far forward. Have handled lots of those big seed bags with it, but I can get the loops on the bag in close to the bucket lip and it does OK. Ken
135 Fan
01-15-2008 11:34:09
The lift capacity is rated at 2500 lbs. However that may be at the lift pins and actual lift capacity would be lower. If you were a good operator you could lower a heavier load if you were fast and smooth enough. It's not recommended though. I've unloaded sod with a bigger skid steer and with some of the wetter pallets you had to start lowering as soon as the pallet was clear of the trailer. It worked better if you had a slight incline up to the trailer. Dave
