Multi Power Works Sometimes
Steven, Avilla
01-14-2008 08:05:45
I have a 165 and the Multipower works great, but only sometimes. At first I thought it might be a temperature related issue...that it wouldn't work if it was fairly cold outside (below freezing) but now I'm not so sure. When it's working, it engages quickly and you can feel it engage and dis-engage. Has anybody heard of this happening before?
glen0820
01-14-2008 10:15:22
 Re: Multi Power Works Sometimes in reply to Steven, Avilla MO, 01-14-2008 08:05:45
Sir your linkage probally needs adjusted. @the sten comeing out of the trans . move the lever up and down it should detent into place. loosen the bolt on the clamp while holding the stem tap down on the clamp 1/4 inch or less. I think the m/p lever should be up at the time.
DavidP, South Wales
01-16-2008 11:20:17
 Re: Multi Power Works Sometimes in reply to glen0820, 01-14-2008 10:15:22
I would just add a bit to Glen's reply. Make sure that the linkage is lubricated and free and that you have positive movement in both directions. You moght be loosing some movement by the rods 'springing' when you operate the MP.
DavidP, South Wales
