Recommended Air Pressure
Hammer
12-04-2000 21:12:49
Am fairly new to tractors and have recently purchased a used MF-245. What should recommended tire pressure be? Fronts are 6.0 x 16. Rears are 13.6 x 28. Doing brush hogging, finish cutting and road grading.
Also, can air be added to bring up pressure to rears that are fluid filled? Or do I need to add fluid only and is that an easy procedure?
Thanks for any help.
heybusdriver
12-05-2000 23:19:16
 Re: Recommended Air Pressure in reply to Hammer, 12-04-2000 21:12:49
third party image
Recommended air pressure for tires on farm tractors are ( front) 4 ply tires 28 lbs, 6 ply tires 36 (rear) (all sizes) min. 12lbs, plowing - increase 4lbs in furrow tire, when heavy loads are carried on tractor pressure must be increased, max pressure 18lbs.
Phil in MS
12-05-2000 05:59:47
Max pressure should be listed on side of tire. I would think from my tires that the front needs 45 lbs or more and the rear needs from 12 to 15 lbs.
I think to check liquid filled tires you need a gage that is for liquid tires. Then park the tractor where the valve stems are at the top of the wheel and check pressure and add air as needed.
