MF 65 diesel power steering pump
dillweed
01-08-2008 05:21:14
My power steering pump leaks at the front seal. Can anyone give my the name and number of a repair shop that can overhaul my pump.
Jeff-oh
01-08-2008 14:09:34
 Re: MF 65 diesel power steering pump in reply to dillweed, 01-08-2008 05:21:14
I have the MF-65 parts book, however there are at least 4 pump styles. What is the SN and engine type? Gas or Diesel? and is SN before or after 685996 diesel or 692981-gas
Bob
01-08-2008 07:54:43
Unless there is a lot of wear and the pump shaft moves around excessively, you should just be able to pop a new seal into it.
DavidP, South Wales
01-08-2008 08:54:12
 Re: MF 65 diesel power steering pump in reply to Bob, 01-08-2008 07:54:43
Agree with Bob,
If you can get the old seal out fairly intact you should be able to find a number on it. Getting a new seal should not be a problem but make absolutely sure that you fit the seal the right way round. Assuming that there is no excessive wear in the pump shaft you will probably find that the old seal is hard or is split.
DavidP, South Wales
