MF 165 conversion to MF 185.
Jason Lee
12-04-2000 06:16:23
Hi,
In our country (not USA) I been told that tractor dealers import used MF 165, change the sleeve and piston with MF 185 and sold in as 185 to get more HP and profit. I have a MF 165 and might just do that to get more HP. How would one know if you have true MF185 or a converted 165 to 185. What are the danger of this conversion?.
I need comments from you guys. Should I do it?
F Anderson
12-06-2000 11:00:33
 Re: MF 165 conversion to MF 185. in reply to Jason Lee, 12-04-2000 06:16:23
You are obviously talking about an english built 165. The later version of these tractors. Had a 212Perkins with a 3.875 x4.5 inch bore&stroke.The english 175 had a 236 perkins with a 3.875x5 inch bore&stroke.The 185 had a 248 perkins with a 3.975x5 inch bore&stroke.These engines are all the same family.So it is possible to put the 248 sleeves into the 212 block.Now changing the sleeves in your 165 will not make it into a 185. Changing the sleeves will change your 212 into a 223 CID engine. This will put your horse power some where between a 165& a 175.
Jason Lee
12-04-2000 06:18:47
Have to rebore the engine block to fit the MF 185 sleeve.
Fred Anderson
12-06-2000 11:31:20
 Re: Re: MF 165 conversion to MF 185. in reply to Jason Lee, 12-04-2000 06:18:47
The service manual for these engines indicates a .040 inch over bore in the biger engine.
Jason
12-07-2000 08:40:34
 Re: Re: Re: MF 165 conversion to MF 185. in reply to Fred Anderson, 12-06-2000 11:31:20
Thank You, This will be usefull information.
Jason
