MH 50 wiring question
Todd Deutsch
01-07-2008 10:06:57
My system is 12 volt. When I unhook the positive cable when it is running it stops the tractor. I'm assuming that if the system is working properly this should not happen.
Todd
garvas
01-07-2008 10:51:15
 Re: MH 50 wiring question in reply to Todd Deutsch, 01-07-2008 10:06:57
Assuming you still have a generator this would probably be right. Unless the tractor is at a very high rpm the generator alone will not keep the tractor running when the battery is removed. If you have converted over to an altenator you may have a problem. Anyway I do not reccommend you continue this practice. Buy you an inexpensive voltage meter. You can fry a generator or altenator doing this.
