MH 44 Brakes
David Garrelts
01-05-2008 17:22:53
Does anyone know how to get the live power clutch off for access to the right brake?
STUDIEDIESEL63
01-06-2008 18:30:45
 Re: MH 44 Brakes in reply to David Garrelts, 01-05-2008 17:22:53
Hi,4 snap rings to remove,1 on the outside of center gear,take gear off,1 on backside were you just tookgear off,1 big snapring,then remove clutch assy.,then last snap ring,then clutch release assy..then you`re there! good luck.(clutch assy.is heavy!)
David Garrelts
01-07-2008 18:13:15
 Re: MH 44 Brakes in reply to STUDIEDIESEL63, 01-06-2008 18:30:45
Thanks,
Does the gear just pull off once you take that snap ring off?
