MF 65 leak
Larry
12-03-2000 18:11:05
I have a MF 65. It leaks trans/hyd oil out of the hole on the bottom of the housing. The cotter pin head is in the hole. It leaks out pretty quickly and then my hydraulics don't work. What do I have to do to correct this?
Ray
12-03-2000 18:29:01
 Re: MF 65 leak in reply to Larry, 12-03-2000 18:11:05
You've got a shaft seal that is leaking,probably
from age.That's what the hole is for so oil
doesn't build up in the housing.The cotter pin
vibrates around and keeps the hole open.splitting
is the only fix.Not that expensive if you do it
yourself.
