44 front pedestal
Eric Platz
01-04-2008 18:49:07
Looking to remove the front pedestal on my 44 special (narrow front) for a project. Just from looking at it I take the bolts out on bottom of the frame holding the pedestal on. What do I do about the steering gear? can I remove the shaft and pull the gear case out with the pedestal or how does it work? any help appreciated thank you.
Brad Gyde
01-04-2008 21:51:34
 Re: 44 front pedestal in reply to Eric Platz, 01-04-2008 18:49:07
Eric,
If you unhook the steering knuckle nearest the steering gearbox and undo the bolts underneath the pedestal, you can roll it from out of underneath... I do believe I had to roll it towards the back (left the tires on to make it easier), and tilt it on a angle. The hole in the "tub" is big enough that the gearbox will come out, tilt is only because of the steer shaft. *Use Caution: the pedestal is quite heavy.. I'd say close to 200 pounds* This was on a 33, and I was changing from a wide to a narrow and vice versa (pulled narrow from mine, wide from parts and swapped)
Another thing to keep in mind is the pin in the knuckle is a tapered roll pin... and will only come out in one direction (or they are on the 33's and 44's, not positive on specials)
Hope this helps.
Brad
