bleeding fuel on 354 perkins
Yellott Canby
01-01-2008 19:47:47
Hello, I was wondering if anyone knew the fuel line bleeding process for a perkins 354 when you change the filters.Thanks YC
phillip d
01-02-2008 06:36:06
 Re: bleeding fuel on 354 perkins in reply to Yellott Canby, 01-01-2008 19:47:47
There is a bleeding screw on the top of the filter assembly,in the center of the two.Pump with the hand pump untill you get the filters both full of fuel and then it will squirt out the top.Then tighten that one and move onto the injector pump.There is a small one on the side of the pume,takes a 5/16 or 1/4 inch wrench.Pump untill it squirts out of there as well and tighten that one aswell.Then loosen an injector line fitting at the injector itself and start rolling the engine over.They can be abit cranky so you may need to use some either to get it running at first,then re-tighten the line and you've got it.pd.
DavidP, South Wales
01-02-2008 11:55:38
 Re: bleeding fuel on 354 perkins in reply to phillip d, 01-02-2008 06:36:06
Hi,
Follow Phillip's instructions but I would suggest a minimum of loosening two or better three injector pipe nuts. You will have more than one rearing to go then!!!!!
DavidP, South Wales
Yellott Canby
01-02-2008 17:13:09
 Re: bleeding fuel on 354 perkins in reply to DavidP, South Wales, 01-02-2008 11:55:38
Hello,
Thanks for the help. I may go out and work on it this evening.
Cheers, YC
Don-Wi
01-04-2008 13:52:12
 Re: bleeding fuel on 354 perkins in reply to Yellott Canby, 01-02-2008 17:13:09
IO'm not saying it's politically correct or not, but if the injectors are as hard to get to like they are on most tractors, I just crack the line at the pump. Still get the same effect, and it'll always pop off after bleeding 1 or 2 lines at the pump.
Haven't had to crack the 3rd line yet when the rest of the system is bled properly.
Not saying it's right or wrong, just what I've done many times in the past instead of fighting with the lines at the injectors.
Donovan from Wisconsin
phillip d
01-05-2008 11:21:01
 Re: bleeding fuel on 354 perkins in reply to Don-Wi, 01-04-2008 13:52:12
That's a neat idea.I always thought that it had to be at the injector to get the air out of the line as well.pd
DavidP, South Wales
01-07-2008 15:00:09
 Re: bleeding fuel on 354 perkins in reply to phillip d, 01-05-2008 11:21:01
Hi,
It is always better to slacken the injector pipe nut, then there is no air trapped in the pipes.
DavidP
