MF 285
Lauro Salinas
12-31-2007 07:46:09
need help. 3 point hydraulics.
how to clean strainer for main pump.
DavidP, South Wales
12-31-2007 07:54:18
 Re: MF 285 in reply to Lauro Salinas, 12-31-2007 07:46:09
Hi Lauro,
Drail the oil from the transmission. Look on the underside of the centre housing and you will see a triangular plate held with 3 nuts. The filter is above this. Remove the plate and remove the wire clip. Remove the nut and the filter should drop out. Use a medium pressure air line jet to clean the filter.
DavidP, South Wales
Lauro Salinas
12-31-2007 08:38:53
 Re: MF 285 in reply to DavidP, South Wales, 12-31-2007 07:54:18
thanks for the reply David, that is exactly what the book say. I have taken the plate off and can not see clip or enough room for filter to come out, help
thanks
DavidP, South Wales
12-31-2007 14:58:10
 Re: MF 285 in reply to Lauro Salinas, 12-31-2007 08:38:53
Hi Lauro,
Have a look in the well in the plate. The clip may be in there or missing. The filter will definately come out through the hole once the nut and possibly metal disc are removed.
Happy New Year
DavidP, South Wales
