new 1552 with a 1580 backhoe att. hitting 3 point arms
steve keppner
12-29-2007 21:22:56
I know this a new tractor, but looking for a little help on a backhoe problem. I have a 1552 compact mf with the 1580 bachhoe att. , when you install the bachoe you must put the 3 point arms down all the way. they are constantly digging into the ground or rock, is there any modification anybody has done to change this? I thought about cutting the plate on the hoe att. to allow the arms to be raised some but not sure if that voids any warr.. Any help with this would be great.
DH in Carolina
12-30-2007 14:03:24
 Re: new 1552 with a 1580 backhoe att. hitting 3 point arms in reply to steve keppner, 12-29-2007 21:22:56
Hello I have a compact Ford 1220 that has the backhoe. I have to remove the 3 point arms and links to put the backhoe on. The arms are easy to remove. You have to remove the 3 point arms on the New Holland TC 30 also. DH
steve keppner
12-30-2007 19:50:14
 Re: new 1552 with a 1580 backhoe att. hitting 3 point arms in reply to DH in Carolina, 12-30-2007 14:03:24
You cant remove the 3 point arms due to there is a lift assist cylinder on the 1552 models.
135 Fan
12-30-2007 12:24:35
Is it hard to take the arms off? Dave
