Starving MF50
Mike Gent
12-26-2007 17:37:22
This message is a reply to an archived post by Ken Le MOAL on February 24, 2007 at 17:07:27.
The original subject was "Starving MF50".
I had a similar problem, plenty of fuel, but would not run for crap...I found a mouse...thats right a mouse in the inlet of the MS carb by the choke. It appearantly crawled in the air intake and made it his home....Removed mouse (and family) runs great!
Good luck
Marty Sacks
12-28-2007 05:25:25
 Re: Starving MF50 in reply to Mike Gent, 12-26-2007 17:37:22
I had a 50 that had a fuel delivery problem. I found it to be dirt in the fuel pick-up tubes on the sediment bowl base. If you unscrew the sediment bowl base out of the fuel tank, there are two pipes that extend up from it, a long one and a short one. Check them for obstruction. The long one is the feed for the two turns normal operation on the shut off knob, the short one for the turn all the way out fuel reserve setting. Regards Marti
Aaron Ford
12-27-2007 13:04:54
I had the same problem, but found that the choke stop had broken and I was running on a closed choke....
Aaron
