44-6 single arm lift
TravisB
12-25-2007 12:22:32
hi all. i have a 44-6 with a single arm lift on the back. i know hardly anything about it nor do i ever remember seeing any implements that would work with it. if anyone here has any information on the lift or its uses please let me know. the 44-6 is my first massey and i'd like to get to know more about it. thanks in advance.
TravisB
12-28-2007 15:49:45
 Re: 44-6 single arm lift in reply to TravisB, 12-25-2007 12:22:32
thanks for the information. i have the shield for the lift and i will make sure it stays on the tractor. thanks again for all the help.
massey333
12-28-2007 16:51:45
 Re: 44-6 single arm lift in reply to TravisB, 12-28-2007 15:49:45
you don't need the shield on there if you don't have the arm on.Just flip your trip pedal over backwards and there is almost no danger,just when you are using something with the lift and have the arm on.Otherwise that shield is in the road for no reason.
TravisB
12-28-2007 09:43:53
does the lift lever come all the way around or does it lift 180 degrees once and then the next trip rotate back down 180 degrees. makes sense to me that it would rotate back the 180 degrees rather than come all the way around.
massey333
12-28-2007 15:24:47
 Re: 44-6 single arm lift in reply to TravisB, 12-28-2007 09:43:53
LISTEN to the others and have that shield on there,That shaft ONLY runs ONE way with no reverse of direction.Over the years there have been a lot of broken ankles,feet and legs from people NOT having that shield on there.That shaft CAN NOT BE STOPPED one it starts until it has made its 180 movement.
MH Poor
12-26-2007 06:34:27
Hi TravisB - When you trip the petal on the right side, be sure your foot is not back by the power lift. When the lift lever comes around, the outcome for your heel will not be good. If you can find a shield that was used there, I'd put it on. I have two 44-6 and a 101jr, and I have been glad the shield was on a couple times. (I'm not big on safety shields, they are usally in the way, but this is the exception.)Good luck.
msb
12-25-2007 19:43:29
It is called a Power Lift. Should be a trip pedal on the right side of the platform. You have to engage the pulley/PTO before the mechanism will work.Rotates the bell crank 180 degrees every time the pedal is stepped on.Dad had a 2 row mounted corn planter and a two row cultivator that was operated with the Power Lift system on his 44-6.
