Neg or Pos Ground
TomfromPA
12-24-2007 06:26:25
How do I know if my tractor is 12 or 6 Volt and Pos or Neg ground? Thanks
1958 Massey ferguson 65
51Pony
12-25-2007 10:04:07
 Re: Neg or Pos Ground in reply to TomfromPA, 12-24-2007 06:26:25
Only dumb question is the one you don"t ask.
Battery cells make two volts. 3 caps (cells) make a total of 6 volts. Six caps will be a twelve volt system.
The positive or negative posts are marked on the side or top of the battery with a plus or minus symbol. The negative going to someplace on the frame is a negative ground. Hope this helps.
TomfromPA
01-03-2008 09:02:31
 Re: Neg or Pos Ground in reply to 51Pony, 12-25-2007 10:04:07
OK it goes to a bolt on the back of the engine. Same thing? Reason I'm asking is I want to buy an electronic ignition kit for it. Any pro's or con's for the Kit? thanks
DavidP, South Wales
12-24-2007 06:32:54
Hi,
It will be 12V. All UK tractors of that time were positive earth and your should be the same.
DavidP, South Wales
TomfromPA
12-24-2007 06:36:32
 Re: Neg or Pos Ground in reply to DavidP, South Wales, 12-24-2007 06:32:54
Thanks David. Felt kind of stupid for asking but had no Idea.
DavidP, South Wales
12-24-2007 09:20:01
 Re: Neg or Pos Ground in reply to TomfromPA, 12-24-2007 06:36:32
Hi,
No problem, that's what we are here for.
Merry Christmas and good luck on the land.
DavidP, South Wales
