Massey 175
johann VI
12-21-2007 09:42:01
What can I expect out of a 1972 Massey 175 with a perkins diesel with 3200 hrs. Has a loader if this is a hint of how it might have been used. What process should I go through to assure happiness instead of a heartache Thanks.
135 Fan
12-21-2007 10:25:26
 Re: Massey 175 in reply to johann VI, 12-21-2007 09:42:01
Sounds like a good low hour tractor. Check out Big Deans site for what to look for. 175's are very good tractors. Dave
DavidP, South Wales
12-21-2007 13:57:36
 Re: Massey 175 in reply to 135 Fan, 12-21-2007 10:25:26
Hi,
Do you have proof that the tractor is 1972?
The 175 ceased production in the UK around 1969 and was replaced with the 178. I do not know if the North American market is the same.
Is the transmission 6 speed or Multi-Power?
Does it have wet or dry brakes? The later wet are more efficient and give less problems. Wet can normally be identified by the 5 notches in each side of the axle housing flange just above the pto.
Engine-wise check for starting efficiency, blow-back through the dipstick hole, oil present around the exhaust manifold and smoking.
Of most concern would be the steering, power steering if fitted and the axle.
Remove the door in the grill and have an assistant move the steering back and forth in the play. Look for play everywhere in the linkage and in the main shaft bushes especially if PAS is fitted. The only place that there should be movement is between the upper and lower arms on the shaft. This is required to activate the PAS. The movement must only be at the point where there is a large nut with a straight-slotted screw in it. Check for gaps under the steering arms at the outside of the front axle. Anything over about 1/8" suggests badly worn thrust bearings at the bottom of the kingpins.
Al in all the 175 is a sound tractor but with a loader on it you can expect to find wear in the steering etc.
Regards
DavidP, South Wales
