massey ferguson mf165 hydraulic adjustments
ko
12-19-2007 07:44:55
how do you adjust the draft and position levers on my mf165 with multi power.the only one that will raise is my draft and it goes to high. please help.
DavidP, South Wales
12-20-2007 09:02:17
 Re: massey ferguson mf165 hydraulic adjustments in reply to ko, 12-19-2007 07:44:55
Hello,
Before thinking of adjustment and if you suspect a problem you should try to find where the problem is. Drain the oil to the level of the lower bolt on the RH round side cover. Remove the handbrake rod if necessary and remove the cover. Inside you will see the pump lever at the bottom and the two vertical levers coming down from above. Operate your control levers and observe the operation. Refer to your manual for working positions etc. If you have no movement when the POSITION CONTROL lever is moved, there is a problem in the lift cover. There is a fine tension spring in the lift cover which acts on the linkage. I suspect this may have broken.
There are special tool required to carry out the correct adjustment procedure. The job cannot be done correctly without them.
If you need any more help please come back.
Regards
DavidP, South Wales
