Massey Ferg 98
Mike Kunz
12-18-2007 10:10:00
Does anyone have any info on the serial # of these tractor to tell what year they are.
Don_G
12-19-2007 17:14:21
 Re: Massey Ferg 98 in reply to Mike Kunz, 12-18-2007 10:10:00
Here is some information supplied by Scottf
"The MF98 is an Oliver 990 with Massey Ferguson sheet metal, seat and of course the MF color scheme. The MF98 does not even get it's own serial number. The serial numbers for the MF98 are out of the same block of numbers as the 990. They added - 943 after the serial number. The Super 99 had been replaced with the 990 by the time the MF98 came out. The MF98 was made in 1959 and 1960. The majority are 1960. The 990 HP was increased slightly over the Super 99 bringing the HP up to 84HP. This was achieved by turning up the RPMs."
Here are some Oliver serial numbers
Model 950, 990 GM, &, 995 GM
1958 530 001 � 530 387
67 828 � 71 112
1959 71 245 � 84 376
1960 84 487 � 95 350
1961 110 064 � 115 469
Hope this helps
Don
dromonedog
12-19-2007 16:09:58
I have tried to get the same info for some time now with no success,
300 Winchester said he had a blue book that might have some info on this he has not contacted me yet .I will let you know when I find any reference to year and s/n
oliver fan
12-19-2007 16:42:50
 Re: Massey Ferg 98 in reply to dromonedog, 12-19-2007 16:09:58
If you look back on your orginal post, you will see where I answered your question.
Better yet, what is you serial number. I will look it up for you.
dromonedog
12-21-2007 09:22:08
 Re: Massey Ferg 98 in reply to oliver fan, 12-19-2007 16:42:50
HI OLIVER FAN
The serial number of MF98 is 86-4764-947
THANKS
oliver fan
12-21-2007 18:48:35
 Re: Massey Ferg 98 in reply to dromonedog, 12-21-2007 09:22:08
You have to many numbers in your serial number. You should have two numbers followed by a hyphen, then three numbers followed by another hyphen, then another three numbers. I can still tell you that, by the first two numbers (86), your tractor was built in early 1960. The extra number that you should not have in one of the (4764). The 947 number is the transmission code. I hope this helps.
dromonedog
12-22-2007 08:47:12
 Re: Massey Ferg 98 in reply to oliver fan, 12-21-2007 18:48:35
Oliver FAN
Thanks for the info,I'll recheck the s/n again. Could you please let me know of the publication or a web site that has this info
Much Appreciated
Dromonedog
