F-40 parts
Leslie A Royer
12-17-2007 07:48:59
I'm finding out that parts for an F-40 model is pretty slim. Which tractor is more like the F-40, the 35 or the 50? Les
Exxon Valdise
12-17-2007 09:03:38
 Re: F-40 parts in reply to Leslie A Royer, 12-17-2007 07:48:59
With the exception of grill and hood, the F-40 is just about a dead ringer for an MF50. MH50 parts interchange also. Some TO35/MF35 parts will interchange as they all use the same gas engine/tranny/rear end/pump/hitch/ect.
Leslie A Royer
12-17-2007 14:12:31
 Re: F-40 parts in reply to Exxon Valdise, 12-17-2007 09:03:38
Ok thanks Exxon. My tractor was in a fire and I want to see if it will still run. The fire was hot enought to ruin soft metal parts like the carb and radiator. I'm looking for a used carb and wiring harness to see if I can start it. I bought a used gas tank for a 35 and it isn't the same. It may fit, but it's smaller. Les
buford
12-17-2007 18:38:12
 Re: F-40 parts in reply to Leslie A Royer, 12-17-2007 14:12:31
agri services wireing harness in alden ny. phone 716 937 6610 I have used them on my F40 and MH 50 they are good and have easy to follow inst. carb. you can use any massey to30 to35 mh 50 mf50 any that use the 134 cont. engine as stated most are like in design check for a salvage yard near you lot's good parts out there rad. available cost about 200.00 you can call Larry @423 442 8451 He can helpwith lot'sof parts
