need info on MF 135 tractor
John DeSimone
12-16-2007 17:51:40
I just bought this tractor a MF 135 model. The tractor will not start. I think the proplem might be electrical Iam not that good with the electrical part of the tractor. The battery is good Iam getting power to the starter on one of the little
wires on the starter when the key is turned on.I was using a test light. I also noticed a noise in the voltage regulator when the key is turned on. I think maby a wire might be on the wrong spot on the starter. If anybody has a wireing scamaits for the tractor I would like to buy a photo copy from you. Or if you can think of any thing else I can check to get her to kick over. I know she is not seized I can turn the engine by hand. I also didnot find any loose or broken wires. Thank you
JOHN
Chris Or.
12-16-2007 18:50:45
 Re: need info on MF 135 tractor in reply to John DeSimone, 12-16-2007 17:51:40
John, there is a neteral safety switch the two speed needs to be in neteral for the tractor to start. Chris
John DeSimone
12-17-2007 17:28:38
 Re: need info on MF 135 tractor in reply to Chris Or., 12-16-2007 18:50:45
Chris, Thank you very much for the information I will try it out tomorrow. This forum is fantastic.
Happy Holidays & Happy New Year Thanks
John
RockyMO
12-16-2007 18:48:20
Hi John, maybe you know this, maybe not. The high low shifter has to be in neutral for the engine to crank. I should have a schematic that I will try to scan and post or email to you.
Rocky in MO.
John DeSimone
12-17-2007 17:35:11
 Re: need info on MF 135 tractor in reply to RockyMO, 12-16-2007 18:48:20
Rocky,
Thank you for the fast response. I will test it out tomorrow. I did not know about the high low speed being in neutral. If you can send me the schematic to my e-mail that would be great. Thank you very much this forum is the best. Have a great holiday and a happy New Year. Thanks again
JOHN
traper
12-16-2007 18:35:37
John Dident say what engine ?But here goes two small terminals one marked [R] puts twelve volts to coil while cranking may have voltage key on. [S]should have power key crank possion only.Top big termial power all time'
Traper
John DeSimone
12-17-2007 17:42:52
 Re: need info on MF 135 tractor in reply to traper, 12-16-2007 18:35:37
Trapper,
Thank you so much for the fast response I will check out your info tomorrow. This is the greatest forum. Have a great holiday and a happy New Year
JOHN
