pto speed
cliff c
12-14-2007 21:45:42
i have a mf204 with loader and hoe and pto which only turns when you are moving---gas engine--35hp i think. ---reverse-a-matic.I was just given a rotovator which calls for a 540rpm pto and max 28 pto hp. Can i use this rotovator???
Les va.
12-16-2007 20:44:12
  204 m/f in reply to cliff c, 12-14-2007 21:45:42
Cliff are you interested in selling the backhoe part of your unit?I have a 204 that is set up for a hoe but don't have one.thanks Les
Les va.
12-17-2007 19:25:56
 Re: 204 m/f in reply to Les va., 12-16-2007 20:44:12
Cliff if your mach. is like mine your pto only turns when you have your foot on the forward or reverse peddle the tractor does not have to be in gear but the peddle has to be down,also the pto is going to turn in which ever direction you have the peddle pushed forward or backward,so on most any equipment it is going to be very hard to use.
cliff c
12-16-2007 23:02:56
Sorry Les
Once you get a hoe, it would be hard to do without it. Do you know anything about this pto issue? Cliff
135 Fan
12-14-2007 22:13:25
 Re: pto speed in reply to cliff c, 12-14-2007 21:45:42
I'm not sure if you have an instant reverse transmission. I didn't think you could get a PTO with instant reverse because it turns backwards in reverse and could really wreck an implement. Does your tractor have ground speed PTO and engine PTO? Ground speed only turns when you're moving. Not good for a rotavator. Someone else can probably help you more. Dave
cliff c
12-15-2007 09:24:02
 Re: pto speed in reply to 135 Fan, 12-14-2007 22:13:25
Thanks for the reply Dave.It is a ground speed pto,and it does turn backwards in reverse.There are no lift arms on the machine, but I was going to put an external 3 pt lift that a friend gave me off of an old international on.I see nothing that would indicate that it is also an engine pto.It didn,t occur to me that I could wreck an implement(I have a rotovator and mower). Cliff
135 Fan
12-15-2007 10:46:33
 Re: pto speed in reply to cliff c, 12-15-2007 09:24:02
I've never heard of a tractor with just ground speed PTO. See if the lever to engage it goes on the other side of neutral. That's how they usually work. Ground speed-neutral-engine speed. If it does, it should keep turning with the clutch half way down and stop when the clutch is fully depressed. That would mean it has a live PTO. See if the PTO reverses when you switch from forward to reverse. If you hook up your rotavator always turn the PTO on and off with the tiller out of the ground. I've heard of broken PTO shafts from not doing this. Dave
