MF202 single clutch disc direction
Phuloi68
12-13-2007 22:16:17
I have a 1961 Massey Ferguson MF202 with gas engine. I split the tractor apart this summer and I am putting it back together.
I do not remember which dirrection the clutch disc should go. I bought a new disc and turned in the other one for core and can"t use it to see which side goes towards engine as I believe it makes a difference.
Hope someone here can tell me or send me a picture. Thanks.
chuck t
12-14-2007 23:01:08
 Re: MF202 single clutch disc direction in reply to Phuloi68, 12-13-2007 22:16:17
go down a few postings on this site to the MF135 posting about hydraulics. Big Dean has responded to it. Go to his response and get on his web site. He is a great help to all of us.
Roger in Iowa
12-14-2007 05:25:08
Is one side of the hub longer than the other? The long side sometimes interferes with the flywheel letting you install it only one way. May not be true on your tractor...
Roger in Iowa
Phuloi68
12-14-2007 10:29:49
 Re: MF202 single clutch disc direction in reply to Roger in Iowa, 12-14-2007 05:25:08
Thanks Roger.
One side is a little longer. It looks like it would go either way. Going by what you say, I would think long side should go towards back end of tractor.
Roger in Iowa
12-14-2007 19:52:42
 Re: MF202 single clutch disc direction in reply to Phuloi68, 12-14-2007 10:29:49
Can you tell by the wear area on the transmission input shaft and take some measurements. I know it is difficult to measure the minute amounts.
Lay the clutch disk up against the flywheel and see how much clearance there is between the hub and flywheel. It will wear so the hub becomes closer.
Sorry I cannot be more help.
Roger in Iowa
