Fuel injector leak.
Tim in Tenn.
12-13-2007 18:52:37
I have a 255 with a 236 engine. I have a fuel leak at the injector on #1 cylinder. Fuel line is tight at the injector. The return lines have new seals on top of each injector. It looks like it's leaking at the seal were the injector goes in the head. Any suggestions? Thanks.
jogl
12-14-2007 04:44:57
 Re: Fuel injector leak. in reply to Tim in Tenn., 12-13-2007 18:52:37
Something to check before you pull the injector; I had a fuel line crack right where the line swelled out into the ball that seals onto the injector. When I loosened the nut off to look at the line and injector the crack closed up and you could not see it.
Good luck,
JP.
