adding a PTO to a massey mf30b
steve wilson
12-11-2007 15:12:27
ok guys forgive me if this is a stupid question. i'm interested in a mf30b. it appears by looking at the rear end that masseys did have pto its just this one was ordered without. is it possible to have the pto put on.. is this just not a feasible idea. if could get the tractor for the right price and get the pto for a couple grand or so i would consider it. any advice would be appreciated
GaryF
12-13-2007 13:43:35
 Re: adding a PTO to a massey mf30b in reply to steve wilson, 12-11-2007 15:12:27
OK if its anything like my old MF204 you can install a PTO and 3point hitch(I did) if it doesn't already have one and yes the PTO will spin in opposite direction while in reverse. Most would use a ORC on the pto shaft to protect gearboxes that don't like to go backwards and you can forget about snowblowing but could be an asset for posthole digging! Parts from a 255/265/275 should work. I used to rototil with mine Eventually I opted for a dual clutch manual shuttle MF40D Which I do prefer...Gary
suptscottyb
12-11-2007 20:51:58
The 30B was an industrial machine with an instant reverse transmission. Check with a dealer. I was told it could be added without splitting the tractor. Great little finish grade tractor - not really something to farm with.....
Gerald J.
12-11-2007 19:00:19
As a minimum it would take a new flywheel, double clutch, several gears and shafts to be added to the transmission and rear end. Probably take splitting the tractor twice and maybe disassembling the transmission IF the mounts for the added parts are machined. Otherwise it would be simple. Find a transmission and rear with PTO and swap the whole thing. Its easier to find a tractor with the PTO already.
I suppose one could mount a crankshaft driven hydraulic pump, and hook up a hydraulic motor to run a PTO shaft, nearly all outside the tractor housings.
Gerald J.
steve wilson
12-11-2007 19:41:38
 Re: adding a PTO to a massey mf30b in reply to Gerald J., 12-11-2007 19:00:19
ok sounds like a very involved and veryyy expensive proposition.
135 Fan
12-11-2007 16:22:12
It might depend on what transmission it has. I think the instant reverse reverses the pto as well. Dave
steve wilson
12-11-2007 18:32:45
 Re: adding a PTO to a massey mf30b in reply to 135 Fan, 12-11-2007 16:22:12
yeah im not sure which tranny it has just kinda wondering if it ever would be a reasonable proposition
