A little more electrical help for the 175, please...
JBMac
12-11-2007 05:26:17
I think I got it nearly whipped but am having problems getting the system to charge. It"s wired according to Big Deans diagram. My oil pressure switch is working and sending 12v to the regulator when running. The wire from the regulator to the alternator has 0v when running. The alternator has 0v output. Does anyone know the best way to test the regulator, or what each terminal on the regulator should be reading while running? Thanks in advance.
kuntryboy
12-17-2007 17:32:31
 Re: A little more electrical help for the 175, please... in reply to rdmytro, 12-11-2007 05:26:17
teighs said: (quoted from post at 07:35:22 12/12/07) Silly question but, have you tried rev'ing up the engine? Single wire alternators need a minimum RPM before they start charging.
not too silly. mine only moves at 1000 rpm.
teighs
12-12-2007 06:35:22
 Re: A little more electrical help for the 175, please... in reply to JBMac, 12-11-2007 05:26:17
