1130
TB1973
12-09-2007 11:29:08
1130D after starting will run for 3 to 4 minutes and then will die. To get it started you must bleed the fuel system to restart. It will continue to run just fine until you leave it set for a day then will run for 3 to 4 minutes and then die again. I have changed the fuel filters but this did not seem to help. The fuel tank is half full. Any ideas?
12-09-2007 15:55:11
 Re: 1130 in reply to TB1973, 12-09-2007 11:29:08
Lift pump.
jogl
12-10-2007 04:01:47
 Re: 1130 in reply to [email protected], 12-09-2007 15:55:11
Yes, lift pump. But before you change it out have you checked that the little screen in the top of the lift pump is clean?
JP.
