HYD. OIL TYPE FOR FE-35
T FORD
12-07-2007 17:14:28
HEY GUYS ! I NEED TO KNOW IF ANYONE KNOWS WHAT TYPE OF OIL I NEED TO PUT IN MY HYD. SYSTEM FOR MY FE-35 MASSEY. I HAD TO PUT A NEW AXLE SEALS IN IT AND I DRAINED ALL THE OIL OUT,IT LOOKED REAL DIRTY.THANKS !
WWilliamBos
12-09-2007 08:27:19
 Re: HYD. OIL TYPE FOR FE-35 in reply to T FORD, 12-07-2007 17:14:28
Go to your local AGCO/MF dealer and get Permatran.
Randyr
12-07-2007 21:46:30
In my MF35 I use 80w90 GL1 type. I got it from a Shell oil dealer, it"s called Dentax.
Don"t use GL4 or GL5 oil because the extreme pressure additves will damage bronze and brass parts. I"m assuming the FE35 and MF35 are the same in this respect.
ric1
12-07-2007 19:27:17
80/90 gear oil is what i put in mine works just fine
Jerry/MT
12-07-2007 18:34:48
I believe the original is API GL-1 90W.
T FORD
12-07-2007 19:22:09
 Re: HYD. OIL TYPE FOR FE-35 in reply to Jerry/MT, 12-07-2007 18:34:48
DO THEY STILL SELL THIS TYPE OR DOES IT CHANGE OVER TO ANOTHER NUMBER?
Jerry/MT
12-07-2007 21:55:10
 Re: HYD. OIL TYPE FOR FE-35 in reply to T FORD, 12-07-2007 19:22:09
If you do a search in the archives, there is a NAPA part number for this fluid. You can also se some of the more modern fluids or 15W30 motor oil.
T FORD
12-07-2007 19:24:40
sorry didnt realize cap lock was on!
