Resistor for Coil
Steven, Avilla
12-07-2007 13:15:46
My MF 165 has a resistor installed in the wire running to the coil. Does anyone know why it would have this? Do all 165's have this?
jb4020
12-07-2007 13:52:37
 Re: Resistor for Coil in reply to Steven, Avilla MO, 12-07-2007 13:15:46
I believe this is to tame down the power to the points so that they dont just burn up.
El Toro
12-07-2007 16:27:56
If that's a ballast resistor it is used to drop 12 volts to 6 volts to your coil. You can buy a new resistor from Napa P/N ECHICR13 or you can buy a new coil from them that has the built in resistor P/N IC14SB for about $15.00. Could be a few dollars higher since I checked. Hal
Gerald J.
12-07-2007 16:01:40
Either its a 6 volt coil or its a 12 volt that requires the external resistor. It also allows an extra contact on the starter solenoid or an added relay to short out the resistor for better starting when the starter is dragging down the battery voltage.
Gerald J.
