MF 1105 Thermostat?
hayray
12-06-2007 16:14:47
Where is the thermostat on a MF 1105? Can't remember if I put on in it a few years ago when I replaced the water pump, have no heat in the cab and have flushed the heater core. Has been real cold here and the heater gauge is not registering.
Fancy Farm
12-07-2007 15:16:41
 Re: MF 1105 Thermostat? in reply to hayray, 12-06-2007 16:14:47
service book says they are interchangeable. I went to NAPA and got 2 new thermostats but they were not identical to the ones I removed so I reused the old ones I have the hood off so if they didn't work no big deal.
hayray
12-08-2007 02:34:51
 Re: MF 1105 Thermostat? in reply to Fancy Farm, 12-07-2007 15:16:41
I guess I will have to drive all the way to the dealer to get them.
hayray
12-07-2007 15:09:32
thanks guys, that is the info I was looking for.
Ray
DODGE BOY
12-07-2007 11:32:24
yes two of them on top of the housing one of them i believe is on the recirculation side so engine warms up faster the second one allows water to start to flow into radiator they are ussually two different temps 160 degrees on the bypass and 180 on the radiator
Fancy Farm
12-07-2007 11:20:11
they it has 2 are on top of the water pump the top radiator hose is attached to the thermostat housing. I put mine back in this morning and fired up the 1105 and drove her around a while after a engine rebuild. It ran like a top.
