MF35 3 pt hitch capacity
Kevin
11-26-2000 08:57:58
Does anyone know the lifting capacity of the 3 point hitch of an early MF35 (gas model)? I just hooked up a snowblower and it will only lift it about 1" if at all. I have been reading about the draft control and the spring assembly on the top link but am not quite sure how it all works. Second question was with regards to the rearend oil: On the hole plug it reads SAF 80 (winter) & 90 (summer). I read on this forum that 15W - 40 motor oil is an acceptable replacement. Comments... Kevin
lee
11-28-2000 17:43:42
 Re: MF35 3 pt hitch capacity in reply to Kevin, 11-26-2000 08:57:58
it should have no problem with a snoblower,mine will lift a 7 ft. 2 feet off the ground. the front wheels should come off the ground before you run out of hyd. power. good luck.
