MF 65 how much oil
PAC
12-05-2007 14:18:01
A friend has just bought a MF65 without a dip stick. How much oil will a MF65 take to fill from empty.
Thanks
J SWAN
12-11-2007 13:38:58
 Re: MF 65 how much oil in reply to PAC, 12-05-2007 14:18:01
IS IT A MULTI-POWER OR STANDARD TRANS.? MULTI-POWER ORIGINALLY TOOK TRANS/HYD . STANDARD TOOK 90 WT.
Jeff-oh
12-07-2007 06:44:20
If you are talking about the transmission it is about 6 gallons. To fill to the correct level. Remove the lowest bolt from the inspection plate, either side is fine. Then fill until the oil just starts to come out of the bolt hole.
Jeff
Aaron Ford
12-09-2007 06:10:25
 Re: MF 65 how much oil in reply to Jeff-oh, 12-07-2007 06:44:20
The manual calls for 8 gallons in the 65. The manual also calls for 80w (below 50 degrees) and 90w (above 50 degrees) straight mineral gear oil. This is known as GL1. Most shops now recommend Permatran III or universal tractor hydralic fluid. I have heard all sorts of discussion on what is best, but I am running UTF and have yet to have a problem with it. Not sure if it is the best, but it has to be better than what was in there...
Ray in NJ
12-05-2007 14:44:54
If it's a gas engine,- 6 qts. with filter. not sure about the diesel.
