1952 Ferguson To-30 Hydraulic Pump
Gene Reichard
12-03-2007 10:02:26
Hello: I Have Rebuilt Hydraulic Pump, Piston & Rings. Lifting Is Vary Slow And It Chatters On Way Up And Will Sag After Time. Do I Need To Bleed Air In System? Or Did I Mess Up Rebuild. This Is My First Hyd. Rebuild. Tractor Is 1952 TO-30 Ferguson
CENTAUR
12-03-2007 11:38:13
 Re: 1952 Ferguson To-30 Hydraulic Pump in reply to Gene Reichard, 12-03-2007 10:02:26
Incorrect oil can cause you the kind of problems you say you have.Just something to consider if you have not. CENTAUR
Gene Reichard
12-03-2007 12:07:20
 Re: 1952 Ferguson To-30 Hydraulic Pump in reply to CENTAUR, 12-03-2007 11:38:13
I Put New Oil In Tractor. For 8n & 9n 1935 to 1952 90 weight. Is That The Right Oil ?
El Toro
12-03-2007 16:50:53
 Re: 1952 Ferguson To-30 Hydraulic Pump in reply to Gene Reichard, 12-03-2007 12:07:20
I think you should use MF PermaTran III hydraulic oil. Its used in the gear boxes too. Hal
PS: You need a MF shop manual too.
El Toro
12-03-2007 14:01:48
What oil did you use in the hydraulics on this TO-30?. You need to use a good grade of hydraulic oil. You don't use 90wt gear oil in a hydraulic system. Hal
Gene Reichard
12-03-2007 17:04:15
 Re: 1952 Ferguson To-30 Hydraulic Pump in reply to El Toro, 12-03-2007 14:01:48
No I Didn't Just Use 90wt Gear Oil. It Was Oil For 8n/9n Hyd Oil 90Wt. For Same Year
El Toro
12-03-2007 19:03:51
 Re: 1952 Ferguson To-30 Hydraulic Pump in reply to Gene Reichard, 12-03-2007 17:04:15
What weight oil did you use in the MF hydraulic's?
Was it hydraulic oil? Hal
