165 torque specs
JAT
12-02-2007 14:03:44
Can someone tell me the torque specs (rods, mains, head, etc.) for a G176 engine? My manual doesn't have them. Also, how does the sealing strips/cord packing get installed in the rear main beaing cap?
Thanks
Aaron Ford
12-02-2007 14:41:49
 Re: 165 torque specs in reply to JAT, 12-02-2007 14:03:44
RODS 40-45 FT/LB
MAINS 85-95 FT/LBS
HEAD 70-75 FT/LBS
ROCKER ARM SUPPORTS 35-40 FT/LBS
MANIFOLD 25-30 FT/LBS
CAM NUT 125-130 FT/LBS
OIL PAN 12-16 FT/LBS (RETORQUE LATER)
Direction of oil holes on rocker shaft- toward push rods. This was reversed in the IT manual.
Rear seal is a rope type. Bolt the rear seal support/rear main into place and feed the string in and tamp into the channel with a long thin rod. You should nearly use up all the string.
Let me know if you have any questions. Aaron
JAT
12-02-2007 18:38:14
 Re: 165 torque specs in reply to Aaron Ford, 12-02-2007 14:41:49
Thanks
