Oil Leak MF 165 w/G176
finsrn
12-02-2007 11:24:47
I bought a MF 165 a few weeks ago from a used tractor dealer who said he rebuilt the engine. I took the tractor out for a 4 or 5 mile drive to run it hard and get it hot and when I got back oil was running out of the weep hole that has the cotter pin sticking out of it. It's black colored oil so I'm certian that it's engine oil and not hydraulic oil. It was not leaking like this before I purchased the tractor. I'm assuming that the rear main seal is out.
Is it possible to have a defective new seal and or could it have been installed poorly?
I called the dealer up and he said he would work something out. He said that installing a new seal requires splitting the tractor. I'm starting to get scared. Do you think the dealer should be responsible for fixing this?
135 Fan
12-02-2007 13:19:01
 Re: Oil Leak MF 165 w/G176 in reply to finsrn, 12-02-2007 11:24:47
If the engine was rebuilt, the dealer should have ran it for a while to check for leaks. If it's a reputable dealer, which it sounds like it is because he said would work something out, they should fix it for you. It would be better to have it fixed than the price reduced because then you don't have to find someone to fix it. 165's are a good tractor. The leak is a relatively minor problem but it requires a fairly involved teardown to get at it. It needs to be fixed though. The dealer should be set up to repair it as it's not a real easy home repair. Dave
DavidP, South Wales
12-02-2007 11:38:18
Hi,
Was the 'engine rebuild' a major part of the sales pitch? Seals are very occasionally faulty but more often will fail if carelessly installed.
Having had the tractor several weeks will probably rule out any direct responsibility of the dealer. Do you have any evidence of what was done or parts used?
I'm not a lawyer (wish I was!) but probably it will be down to the good will of the dealer.
Good luck
DavidP, South Wales
