MF202 hydraulic arms will not go down
James V.
12-02-2007 07:52:05
I was wondering if anybody knows how to fix this problem I am having with this Mf202. I have replaced the pump and made shore that the levers were in front of the rollers when putting the top cover back on.Can anybody help Thanks James
DavidP, South Wales
12-02-2007 09:13:58
 Re: MF202 hydraulic arms will not go down in reply to James V., 12-02-2007 07:52:05
Hi James,
First of all, is there an isolating valve fitted that could be in the position to hold the arms 'up'? I think that your problem may lie with the oscillator link under the pump. If for some reason the oscillator is not being driven by the pump shaft the valve can stick.
Drain the oil level to the bottom bolt on the side cover and remove the RH cover. Operate the control levers. You should see the vertical levers pushing the pump lever forward. If there is no sign of movement operate the pump lever by hand. The arms should then fall.
This will point to where the problem is.
DavidP, South Wales
