water pump pulley mf50
Richard Foley
12-01-2007 11:30:40
Any advice on removing water pump pulley from old pump and installing on new.Is this possible without a press ? Thanks Richard
Marlowe
12-01-2007 14:25:42
 Re: water pump pulley mf50 in reply to Richard Foley, 12-01-2007 11:30:40
the shaft is hardened so cutting will do you no good. we use just a 20 ton shop press and they all come off never have had to use heat. Do not pound off with a hammer or you will be buying a new pulley
Richard Foley
12-01-2007 15:03:10
 Re: water pump pulley mf50 in reply to Marlowe, 12-01-2007 14:25:42
Thanks ,I guess I'll have someone press it off for me. Richard.
garvas
12-01-2007 12:17:06
I had one last year that took a LARGE press and TORCH to get it off. If the water pump is not going to be repaired you could cut the shaff off and drill it out of the pulley. A lot of work but it can be done. My local tractor shop (whom I have several dollars with) did the pressing off for free. I gave the yound man a 10 spot for all his hard work. Lots luck.....
