MF 135 leaking at top of steering column
Matthew Rice
12-01-2007 09:15:07
My 135 is leaking fluid from the top of the steering column (under the hood). The screw holds a bracket on and it will not tighten up, I guess it is stripped out. Is there an easy fix for this or will I have to take it apart and drill and retap the hole for a bigger screw? Matt
Dean
12-01-2007 12:43:21
 Re: MF 135 leaking at top of steering column in reply to Matthew Rice, 12-01-2007 09:15:07
Matt:
It appears that the one of the seals in the power steering control valve is leaking allowing PS fluid to leak into the steering column.
Unfortunately, there is no easy fix for this problem.
Dean
