Massey Ferguson 235 Hydraulic problem
Danny
11-24-2000 18:05:23
The lift arms will not lift up properly unless lever is pushed all the way up to the " constant pumping" position. Once the arms are up, lever can be pushed to the " Transport" position and arms will stay up. However, the lift arms will not hold at a set position. They will either lift all the way up or go all the way down. The lift can be some what set at a point by using the Draft control lever. Is there some adjustment to correct this problem?
Larry MI
11-24-2000 19:59:35
 Re: Massey Ferguson 235 Hydraulic problem in reply to Danny, 11-24-2000 18:05:23
Danny, please excuse me if I'm too inexperienced to know what I'm talkin' about but I had to read the darn manual to figure out how to work the lift arms properly. I learned that you can use one or the other but not both. The unused control should be all the way back (up) - except the Position should only be in Constant Pumping if you are using the aux hydraulics (loader, etc.). The Draft control should be all the way back (up) for Transport to work as expected. I tried forever to mess with both at once but the manual set me straight! Where was that experienced farmer when I needed him?!
