Oil on Tire
Woodchopper
11-29-2007 03:54:52
Occasionally oil leaks from the rear axel and gets on the tire. Is there a solvent that is safe to use on the tire or is wiping off sufficient? I plan to replace the seals as soon as I find a way to remove the loaded tires safely.
Thanks, Dennis
MF Poor
11-29-2007 13:10:29
 Re: Oil on Tire in reply to Woodchopper, 11-29-2007 03:54:52
Hot soapy water and a scrub brush
Steve IA
11-29-2007 11:02:14
A significant % of the rubber in the tire is oil. Oil on the surface will not hurt anything. Wipe it off and roll on. Also, products applied to the surface of the tire to prevent/reduce weather checking are pretty much worthless. How well a tire stands up to the elements is determined by the anti-oxygen/ozone oils mixed INTO the rubber when it is compounded. Most tractor tire will have plenty, auto tires won't. Auto tires wear away before the elements have a chance to do their dirty work. Steve IA Firestone Ag Tire Process Engineer - retired
