Aux. Hydraulics on MF165
Curt
11-24-2000 08:24:47
I have a '67 MF 165 that I am considering putting a front end loader on for loading hay. I am planning on adding another hydraulic pump for the loader. What kind of advice or experiences are out there concerning either (A) an internal auxillary pump, or (B) a front mounted pump. The labor to install is not a big issue to me because the hydraulic lift cover is coming off and the tractor will be split for repairs anyway.
Big Dean
11-24-2000 21:16:17
 Re: Aux. Hydraulics on MF165 in reply to Curt, 11-24-2000 08:24:47
Curt my advice would be go with the front pump. I think you would be much better satisfied with how your loader works I have mounted a lot of loaders on the Massey tractors using a front pump, the factory auxiliary & the three point hydraulics
Pat
11-25-2000 07:01:07
 Re: Re: Aux. Hydraulics on MF165 in reply to Big Dean , 11-24-2000 21:16:17
Dean, do you have any specifics on the best model of front mount pump to use, where to get it, and any installation tricks to watch for. I have been using a loader on my MF65 with the internal 3-point pump and am getting tired of having to pour myself a coffee while waiting for the loader to lift.
Larry MI
11-24-2000 20:13:41
Curt, I inherited an MF 135 gas with my farm last year and had a loader installed by a MF dealer. I shopped around a bit and a Woods was about the same as the MF232 loader that I had installed. Cost about $4100 labor and all which isn't cheap but the work was great. Only uses the internal pump on Constant Pumping and a simple manual valve to switch over from the 3-point. It has remarkable lifting force and reasonable speed (I'm not loading for a living!). Unless you must have both your 3-point and loader operating at the same time, you can go without the front pump. At times I can't believe I put on a loader worth more than the tractor itself but the thing has been a dream for some major stone hauling, grading and soil moving.
