Hydraulics problem MF50 1959
Terry Stewart
11-23-2000 21:51:40
My MF50 hydraulics seem to work fine initially. Except after running awhile with the bushhog running at cutting level it will slowly begin lowering on its own. Once it drops completely the hydraulics will not lift at all. However after the tractor is off a while the hydraulics will respond again. Any ideas on what the problem may be? A friend told that it may be a filter. Anybody have any suggestions? Thanks Terry
CHRIS-MF35
11-26-2000 17:21:57
 Re: Hydraulics problem MF50 1959 in reply to Terry Stewart, 11-23-2000 21:51:40
what fluid is in the trans? it should be sae 80-90. if it is the sae 10 stuff they sell for most tractors then it is getting way to thin when it heats up and not building pressure. that thin stuff just doesn't work to well in these fine old machines. good luck.
Jack in NB
11-24-2000 03:34:39
Plugged filter might cause it, and it might be blown o-rings in the standpipe, but the problem is consistent with a tired pump. You didn't mention jumpy behaviour. Blown valve o-rings in the pump cause loss of lift and jumping, but that's probably ruled out.
As the oil warms up, it becomes thinner, and the pump simply cannot deliver enough.
Filter is easy to check through the left inspection port (PTO lever mounted in it). Run the rear wheel up on a 6x6 to tip the oil away from the left side, so it doesn't run out when you crack the cover loose.
Be sure to replace the safety wire when re-installing the filter!
You can check for blown o-rings while the cover is off. With a load on the 3-point, block the tractor so it can't roll, start it at idle, lift the load, and with a light and mirror look for oil being driven under pressure out of the top of the pump or the standpipe ends. No leakage? tired pump. Overhaul time!
Repair will involve removal of the pump - shop manual (MF or I&T) strongly recommended. They're available from our hosts here - top left of the page.
Robert
11-24-2000 05:17:13
 Re: Re: Hydraulics problem MF50 1959 in reply to Jack in NB, 11-24-2000 03:34:39
I would add to what Jack said that there is a pretty good video available on this site as well. It covers both the old style pumps and newer style ones used in the 50. It is likely, given that your tractor is a '59 that it has the newer style pump with a filter. Do not be too surprised if it doesn't have one at all 'though. Mine doesn't and its about the same year. On the video they show you pretty well everything. If you aren't an expert it will inspire confidence to do it yourself. Good luck
