Pony Crank shaft thrust clearance problems
Eddy62
11-25-2007 12:45:45
I have a N62 engine I had the crank reground.The block was replaced as the old one was cracked. The problem I'm having now is when I set the crankshaft in I have 0.15 thrust clearance . This should be .002 -.008. I have no shims installed so there's no place to go .What to do?
Should I have the material ground off the crank?
Should I shim behind the front bronze fixed thrust washer?
Or make a thicker bronze thrust washer for the inner side. Problem is what type of bronze do they use for these?
Your thoughts greatly appreciated
ED
Old Iron Larry
11-25-2007 13:36:48
 Re: Pony Crank shaft thrust clearance problems in reply to Eddy62, 11-25-2007 12:45:45
There are shims that go on the front of the crankshaftbetween the crank and frony thrust washer. I made some from a beer can and they worked fine.
Eddy62
11-25-2007 14:05:15
 Re: Pony Crank shaft thrust clearance problems in reply to Old Iron Larry, 11-25-2007 13:36:48
Thanks for the reply . But the problem is with no shims on the crank I have to much clearance.
ED
Old Iron Larry
11-26-2007 10:47:52
 Re: Pony Crank shaft thrust clearance problems in reply to Eddy62, 11-25-2007 14:05:15
You may need new thrust bearing washers or you might not have one installed on both sides.
