INDEPENDENT PTO,MF 135
STAN
11-23-2000 16:22:56
I CHANGED HYD. OIL IN TRANS.NOW PTO WILL NOT WORK,HELP PLEASE.
Big Dean
11-24-2000 21:29:05
 Re: INDEPENDENT PTO,MF 135 in reply to STAN, 11-23-2000 16:22:56
I have run into this problem a lot when I was a Massey mechanic. your PTO pump is probably getting weak & lost it's prime when you drained the oil. Usually if you will let them idle for 5 or 10 minutes with the PTO in the off position they will pick up the oil & be ok.
